Headlight Adjustment E82
Post by M60NJP » 01 Jan 2012, 14:27
Hopefully something few will ever need, but it is possible to upset the alignment when installing after-market bulbs (apparantly!):
The plastic geared wheels at the top is the vertical) adjustment ONLY .
The horizontal adjustment is less obvious - if you're looking down at the headlight the silver box on the outer side of the headlight appears to adjust horizontal (left/right). You can move it by hand to change the left and right position which probably explains how you can change the alignment accidentally!!
Not the most robust thing I've ever seen!
