Do you recognise this Sat Nav?
Please post up here any/all information, questions, comments, product recommendations etc about all aspects of in-car entertainment
Colie
Car model: BMW 3 SERIES 330 Ci M-Sport Vert
Post by Colie » 08 Jul 2014, 22:44
Hello people!
I have a Kenwood KVT627DVD head installed in my car (with a 500w amp in the boot I've found - car I've just bought :-? ). By the looks of the manual some of the components are not built in i.e. external inputs. One of these is Sat Nav that feeds on to the display of the KVT. I don't know who the manufacturer of the sat nav is or where the main unit is yet (have not had the time to look). Does anyone have any idea? :-??
Thanks
Colie
spirit
Re: Do you recognise this Sat Nav?
Post by spirit » 08 Jul 2014, 23:49
Open the boot and passenger side behind the trim in the left side maybe
Post by FAB_BMW » 09 Jul 2014, 07:05
Usually these aftermarket flip outs have a 'brain' elsewhere in the car, usually behind the glovebox.
Post by Gus247 » 09 Jul 2014, 08:39
definitely not one I've seen before bud... GLWTSearch though...
Worst case, pull ALL the interior out and follow the wires along! :)) (Just kidding!) As Fred said, most likely a little module somewhere, probably hidden behind the glovebox or one of the rear panels as Andy suggested...
Is there an external SatNav GPS aerial? If so, may be an idea to follow the wiring back from this...
Also, maybe worth having a look on the Kenwood site. Obviously the unit has to be compatible and it may actually be a Kenwood bolt-on for which there should be a manual available to download... There should also be some screen shots which you can use to compare the screen on yours.... worth a shot :)
Colie
Post by Colie » 09 Jul 2014, 08:54
There are some, what I can only guess, are aerials either side of the windscreen that have small kenwood labeled boxes attached to them. Small insulated wires going from top to bottom (connected to the small boxes at the top). I will check the Kenwood site again as suggested.. And have a route around the car....
Post by Gus247 » 09 Jul 2014, 08:55
Colie wrote:There are some, what I can only guess, are aerials either side of the windscreen that have small kenwood labeled boxes attached to them. Small insulated wires going from top to bottom (connected to the small boxes at the top). I will check the Kenwood site again as suggested.. And have a route around the car....
Seems likely to be a Kenwood unit then... :) Should make finding a user guide a bit easier...
Colie
Post by Colie » 09 Jul 2014, 18:25
Gus247 wrote:......
Good call!!!
Looks like it could be the Kenwood KNA-DV3200 or DV2200!! MAP DVD ROM driven, funnily enough there is a DVD drive in the boot but i thought it was a redundant drive that had not been taken out! :)) HOOWWWWWWWW embarrassing! :oops: :d
.Image
Yep!
It's got some sort of sticky goo over the front of the drop down cover, this is why I thought it was redundant!!
Stu_c
Car model: E92 335i
Post by Stu_c » 15 Aug 2014, 10:58
I used to have a kenwood unit, with satnav, there was a separate box that connects to the headunit, that holds a SD card with the maps on etc if that helps
Colie
Post by Colie » 15 Aug 2014, 12:58
Thanks Stu, found the unit in the boot!! I thought it was for the cd player! :oops:
Stu_c
Car model: E92 335i
Post by Stu_c » 15 Aug 2014, 14:06
No comment ;)
Return to “In-Car Entertainment ICE”
