E91 Misfire under load
Benaal
Car model: BMW 325i Touring (2008)
Post by Benaal » 23 Jul 2017, 08:25
Hi all,
had this problem a while back but it's back again.
Basically, when booting it on the motorway I'll get to about 60 and the whole engine will judder and i get the EML on. The code reads Cylinder 1 misfire.
I've had cylinder 1 coil replaced, as well as cylinder 6, just in case they numbered them wrong. still Cylinder 1 misfire.
On top of that, I've been having trouble starting it over the last few weeks. There's been the odd occasion where it turns 6 or 7 times before it takes.
Also, I am getting the smell of burning fuel at low speeds and particularly when I stop at lights etc.
To my untrained brain, this sounds like a fuel mix issue, but I was wondering what the collective experiences here thought?
Thanks,
Martin
Re: E91 Misfire under load
Post by M60NJP » 23 Jul 2017, 09:09
Hi Martin and welcome.
If the ignition 'side' is all sorted it certainly reads like a fuelling issue - the fact it's becoming difficult to start suggests you have an air leak somewhere. I'd start by tracing each patiently and check for splits or badly seated joins.
Post by Lewy » 23 Jul 2017, 21:23
Dodgy spark plug?
Benaal
Post by Benaal » 06 Aug 2017, 12:00
Just to put this to bed for now, I had the battery tested for another reason and found that it was faulty. Now replaced the battery and touch wood I haven't had the problem since. I'm wondering whether there was a voltage issue with running at high revs? Could it confuse the ECU?
It would certainly explain why it was dodgy when starting.
Post by M60NJP » 06 Aug 2017, 12:10
Benaal wrote:Just to put this to bed for now, I had the battery tested for another reason and found that it was faulty. Now replaced the battery and touch wood I haven't had the problem since. I'm wondering whether there was a voltage issue with running at high revs? Could it confuse the ECU?
I wouldn't expect a dodgy battery to affect running at any particular rev/speed. The voltage remains fairly constant at all engine speeds. More likely to be related to your other post!....
