Smoking Volvo!!
Many if us have other cars/motorbikes which aren't Baveria's finest.....threads about them go here!
Smoking Volvo!!
Post by M60NJP » 29 Feb 2016, 09:53
I pulled up at a roundabout (we've a few here!!) and there's a puff of smoke drifting forward from the rear of the Volvo! I blame the usual diesel drivers clattering around me. But, no - I get home and the rear caliper is smoking. I fitted new pads a few weeks ago.
So, I whip the wheel off (after I let it cool down!!) take off the caliper and............
There's two perfectly good pads, properly seated, caliper piston looking good and moving freely. Absolutely nothing visibly wrong. I re-greased the pad seats, pushed the caliper back in (it's one of those PITA wind-back ones...grrr...) and reassemble. Handbrake self-adjusts, pump the pedal and the wheel turns freely!!
I have absolutely not idea what caused it!!
Re: Smoking Volvo!!
Post by Gus247 » 29 Feb 2016, 10:04
So the wheel was pretty hot when you got home? Was there more brake dust on that particular wheel in comparison to the others?...
We had a sticky caliper on the 'vert which was intermittent. I went through the same process (disassemble, lubricate where needed (ooooh errr), reassemble) all appeared ok until the next time it happened.... At which point, I called it a day and replaced both the front calipers, figuring if one had gone, the other probably wouldn't be far behind...
Hope you get it sorted bud....
Re: Smoking Volvo!!
Post by cockneyrebel » 29 Feb 2016, 10:29
Just had a chat with a 'volvo' chap, says it sounds like a temporary seize, bit of crap in it that later fell out.
Sent from my RM-875_eu_euro1_212 using Tapatalk
Re: Smoking Volvo!!
Post by M60NJP » 29 Feb 2016, 10:34
Thanks both. The other possibility is the handbrake mechanism was sticking - it's been a bit temperamental for some time, but released OK when I tried it.
Re: Smoking Volvo!!
Post by Gus247 » 29 Feb 2016, 13:29
M60NJP wrote:Thanks both. The other possibility is the handbrake mechanism was sticking - it's been a bit temperamental for some time, but released OK when I tried it.
That would also make sense given the decent condition of the pads.. does it operate a set of 'shoes' inside the rear discs like the 36's do?
Re: Smoking Volvo!!
Post by RayB » 29 Feb 2016, 16:21
You were going too fast!! That was the Volvo automatic brake system being deployed for going over 40mph :)
Re: Smoking Volvo!!
Post by M60NJP » 29 Feb 2016, 16:51
RayB wrote:You were going too fast!! That was the Volvo automatic brake system being deployed for going over 40mph :)
It was trying to apply a flat cap at 30 mpg too.....so all is well!
Re: Smoking Volvo!!
Post by M60NJP » 01 Mar 2016, 09:58
All well last night - wheel itself was cold and no smoke. Difficult to judge today due to the rain!!
MoT later in the year might be interesting.............
Re: Smoking Volvo!!
Post by cockneyrebel » 01 Mar 2016, 14:53
As it's getting on a bit, perhaps it was having a hot flush / Menopause !! :-):-)
Return to “Members' Non-BMWs”
