Space saver wheel.
Andyc58
Car model: Bmw 318i
Space saver wheel.
Post by Andyc58 » 05 Dec 2017, 08:36
Hi peeps would this tyre fit on my 2011 318ise e90 ??
https://m.ebay.co.uk/itm/BMW-T-125-80R1 ... Swv-ZaJCGQ" onclick="window.open(this.href);return false;
Re: Space saver wheel.
Post by M60NJP » 05 Dec 2017, 09:01
Tyre or wheel!!!
Depends what size wheels you currently have and the offset of yours vs these. (If you mean the wheel!!)
Andyc58
Car model: Bmw 318i
Post by Andyc58 » 05 Dec 2017, 09:06
All i know is that i have 235 35 19 on the car
Post by M60NJP » 05 Dec 2017, 10:16
That's the tyre size which of course is not the same for a space saver!!
The offset on the E46 is ET47 ands on yours is ET34 - so, assuming the post is correct on Ebay, it won't fit!
dowot
Car model: e46 330i se
e36 318is
e30 316i lux
Post by dowot » 05 Dec 2017, 18:19
Offset wont matter so much with narrower wheels.. junior has an e46 space saver for his e92 335d. At the moment hes running 205 50 17 x 7j et 47 with spacers only for cosmetics . He used one as a spare without on the rear and was fine just lost...:)
dowot
e36 318is
e30 316i lux
Post by dowot » 05 Dec 2017, 18:39
mind you any bmw wheel that fits and clears your brakes will be fine with the correct tyre size... give this a go .
http://www.willtheyfit.com/index.php?wi ... offset2=47" onclick="window.open(this.href);return false;
