e46 strange connection to manifold down pipe
Coupe2008
Car model: BMW 320d e92
Post by Coupe2008 » 15 Nov 2017, 11:40
Hi all. I have been trying to sort my Grandson's e46 320d year 2003, which failed the MOT with an exhaust leak. Sorted a rear hanger problem but there seems to be a leak around a collar/tube which fits over the downpipe from the exhaust manifold . Not seen any fittings like this on searching for exhaust sytems. Has anyone got any ideas ? There is no flex joint on the system just solid pipe work. :crazy: :crazy: :crazy:
Regards
Re: e46 strange connection to manifold down pipe
Post by FAB_BMW » 15 Nov 2017, 12:15
Under that collar/tube is a flexi-pipe, they are prone to splitting. My wife had it go on her 320d. We replaced with a genuine bmw part, but lots of people just fit a decat pipe.
Coupe2008
Post by Coupe2008 » 30 Dec 2017, 11:16
FAB_BMW was correct. It took a bit of arm wrestling but with an angle grinder ( after opening up the metal 'cover' ) there was indeed a split flexy pipe. This was cut off and a replacement sourced from e-bay ( each end matched the pipe it connected too) clamped on along with some exhaust sealing paste. Car past MOT without issue. A car lift was essential to get access though.
Sorry about the pause in replying.
Post by M60NJP » 30 Dec 2017, 11:18
Glad you got it sorted and thanks for feeding back.
Return to “Exhaust”
