Auto button on climate control
Andyc58
Car model: Bmw 318i
Post by Andyc58 » 16 Jun 2017, 17:43
Hi people. When I go to push the auto button it won't even push in. Is there any reason why I can't use this button.??
E64 650i
E85 Z4
E46 318i
E39 525i
Re: Auto button on climate control
Post by Maxwell » 16 Jun 2017, 18:06
do you have iDrive ?
Andyc58
Car model: Bmw 318i
Post by Andyc58 » 17 Jun 2017, 00:47
No but the manual says it's avaible on my car. Seems like it's been clued for some reason
Post by M60NJP » 17 Jun 2017, 08:59
Which model of 318? (would be useful to detail your car in your profile so we don't have to ask!)
Andyc58
Car model: Bmw 318i
Post by Andyc58 » 17 Jun 2017, 10:57
318i se 2011
E64 650i
E85 Z4
E46 318i
E39 525i
Post by Maxwell » 17 Jun 2017, 11:10
You have option $534 which is Automatic air conditioning so it should work, as a rule buttons do not push in as such they are one touch.
Try this - Engine must be running and warm, set temps to max and touch the Auto button, Led should light up and blower start to run. If you also have the little thumbwheel between the air vents make sure it is set to Red.
Andyc58
Car model: Bmw 318i
Post by Andyc58 » 17 Jun 2017, 13:29
I've got it working. It's a sticky button. Pushed it in and it works. Only problem now is I can't get it off lol. Will take it apart and clean it.
Singvogel
Car model: F30 LCI 330D M-Sport
Post by Singvogel » 17 Jun 2017, 19:51
I have mine on auto all the time - never switch it off.
Only pressed the button once - when I first got the car.
Fan on auto - snowflake button pressed - and that's it.
Always had a BMW since I collected my first one in Munich - a 528i in June 1982.
Andyc58
Car model: Bmw 318i
Post by Andyc58 » 17 Jun 2017, 21:45
Does anyone know what the red and blue scroll button does next to the dtc button
Singvogel
Post by Singvogel » 17 Jun 2017, 22:09
From the handbook:
Knurled wheel for varying temperature in upper body area.
Towards blue: cooler
Towards red: warmer
Set interior temperature for driver and front seat passenger is not changed.
Have you seen this video on how the Climate Control works:
https://www.youtube.com/watch?v=-snHTpWpNKQ" onclick="window.open(this.href);return false;
Return to “General”
