White smoke
Stevieboy33
Car model: BMW E91 320I
White smoke
Post by Stevieboy33 » 07 Jan 2018, 05:10
Hi there. Ive got a e91 320i its started smoking from exhaust. White i think. Also leaking oil. You can smell it in the cab after a while. Also poor fuel consumption. Any ideas? After reading online ive bought oil separator valve and hoses to go with it, was wondering if im on the right path or barking up the wrong tree?
Sent from my LG-D851 using Tapatalk
Re: White smoke
Post by M60NJP » 07 Jan 2018, 08:39
White smoke is often a symptom of oil and water mixing (under pressure) and being combusted in a cylinder (or more) - in plain English, head gasket or cracked head. Rather than throw any more money at it, suggest you get a sniff test done and find out for sure.
Stevieboy33
Re: White smoke
Post by Stevieboy33 » 07 Jan 2018, 08:53
Thanks for your reply ill take it to the garage
Stevieboy33
Re: White smoke
Post by Stevieboy33 » 07 Jan 2018, 08:55
Just to mention i havent fit the oil separator valve yet. Is it worth a shout?
Re: White smoke
Post by M60NJP » 07 Jan 2018, 10:03
Stevieboy33 wrote:
07 Jan 2018, 08:55
Depends how much it was and whether you can return it.............
Re: White smoke
Post by cockneyrebel » 07 Jan 2018, 10:36
If I were you I'd take it to the garage as it is, they need to see her as she is, but take the bits you've bought with you.
Stevieboy33
Re: White smoke
Post by Stevieboy33 » 08 Jan 2018, 18:43
Update is the car is booked in at garage for a pressure test. Thanks for the replys
Re: White smoke
Post by cockneyrebel » 08 Jan 2018, 19:27
Good luck, hope it's minimal grief for you and the motor.
Stevieboy33
Re: White smoke
Post by Stevieboy33 » 10 Jan 2018, 18:56
Update now is, its been at garage. Its not the head gasket or the valve seals. The white smoke is water they have told me to keep and eye on coolant. Seems as though exhaust is blowing out water. There is still the oil leak they would start with rocker cover gasket..... I think ill start with the parts i bought and do the rocker cover. Any more ideas would be much appreciated. Forgot to mention they dont know were oil leak is coming from the engine is covered in it.
Re: White smoke
Post by RayB » 10 Jan 2018, 19:00
Is it used daily?
