Door card removal and speaker replacement
AK_
Car model: '03 E46 M3 SMG vert
'97 E36 M3 Evo saloon - sold
Post by AK_ » 07 Dec 2011, 10:07
Can anyone give me a rough guide to speaker replacement as Lewy only has 1 out of 4 door speakers working so its going to be me that has to end up fixing it!
'03 M3 vert
'97 M3 Evo saloon - sold
Being second is to be the first of the ones who lose - Ayrton Senna
Re: Door card removal and speaker replacement
Post by Gus247 » 07 Dec 2011, 10:13
hi mate - is this on Lewy's car then I guess?
AK_
Post by AK_ » 07 Dec 2011, 10:27
Gus247 wrote:hi mate - is this on Lewy's car then I guess?
Yep, I thought it sounded a little rear biased so played about with fade and balance and found the reason
'03 M3 vert
Post by M60NJP » 07 Dec 2011, 10:39
What do you want to know?
There's 5 in the front - 2 x door speakers, 2 x tweeters and 1 x dash centre. I hope I'm wrong but I fear it may be more than speaker replacement if more than one doesn't work?
Post by Lewy » 07 Dec 2011, 11:05
haha, quality!! Cheers AK!
Basically when you use the left / right fader, all the way to one side gives off no sound at all and on the other side gave a very muted sound - that's right isn't it AK? Assuming that the biased was all the way at towards the front when we did this test although I wasn't in the car for all of this...
Post by M60NJP » 07 Dec 2011, 11:10
Lewy wrote:haha, quality!! Cheers AK!
Almost certainly not the speakers unfortunately (as both front channels are not working correctly). I had something similar on mine and the amp had water damage (not uncommon on E64). As it's a simple job, I'd take the amp out of the boot and check all the connections are clean and that there is no sign of water ingress. Clean up the connections (assuming the amp isn't water damaged) and re-wire (without refitting) and see if any/all channels come back?
Post by Lewy » 07 Dec 2011, 11:15
Will give it a go, thanks Neal
AK_
Post by AK_ » 07 Dec 2011, 11:18
Basically the mid in the driver's door works, the mid in the left and both tweeters do not. Didn't realise there was a center speaker but that doesn't appear to work either. Where's the amp located in the boot?
'03 M3 vert
Post by M60NJP » 07 Dec 2011, 11:27
AK_ wrote:Basically the mid in the driver's door works, the mid in the left and both tweeters do not. Didn't realise there was a center speaker but that doesn't appear to work either. Where's the amp located in the boot?
There's a possibility there isn't a middle one - dunno the spec on Lewy's but he may not have the same ICE. Easy to find out, the speaker cover prises off and you'll see (from outside) if there's a speaker!
The amp is behind the panel in the LH side of the boot as you look into it from the rear. The covering panel is quite large and a bit of a faff to remove (watch out for the torx bolts that screw upwards) When you get that out, the amp should be in plain site. All the pins on mine (there's a lot!) were covered in white fur from water damage. Electircal terminal cleaner (Maplins) and a combination of old toothbrush and fine wire brush............assuming no internal damage!
AK_
Post by AK_ » 07 Dec 2011, 11:51
Cheers Neal, I suspect my phone will be ringing shortly with a request for some of my time...
'03 M3 vert
