Shanes E92 335i
Shanusascarabus
Car model: Focus Rover BRM
Re: Shanes E92 335i
Post by Shanusascarabus » 19 Aug 2017, 17:09
Almost looks crushed...
Shanusascarabus
Re: Shanes E92 335i
Post by Shanusascarabus » 08 Oct 2017, 20:03
Not updated for a while, but in the last few weeks I have...
Put 2 front tyres on ( michelin pilotsport3 )
Hunter alignment
Oil filter housing gaskets
Full oil/filter service
Full new suspension ( Sachs struts/eibach pro kit springs ) and all new sundries.
And finally I have ordered a set of ATE discs and Textar pads ( I've heard this is OE suppliers ).
Car is running well still but will need a new radiator soon due to weeping on either side and need to replace the other two tyres
Shanusascarabus
Re: Shanes E92 335i
Post by Shanusascarabus » 16 Oct 2017, 22:25
Well I fit the disc/pads all round and the car no longer sounds like a freight train when braking... just silence... heaven :)
Also feels a lot more responsive now, however I can't try too much till the brakes are bed in.
Handbrake now needs adjusting too so that's going to be interesting... hate handbrake tinkering
Shanusascarabus
Re: Shanes E92 335i
Post by Shanusascarabus » 21 Oct 2017, 22:12
I'm after a little advice which I may have asked before but I can't remember any advice given.
My car is running on aftermarket 8.5j wheels all round and I've now fit a full set of Michelin Pilotsport 3 tyres ( 235/35/R19s but I don't want to ruin them prematurely.... can I ask what pressures you would recommend on this setup ??
Reason I ask is the wheels are not staggered as per original setup..... all 4 corners are uniform.
Thanks guys
Re: Shanes E92 335i
Post by Metroreg » 21 Oct 2017, 22:20
Looking at an app I’ve got on my iPhone
For the m3
And for your car but has the 225 tyres
Shanusascarabus
Re: Shanes E92 335i
Post by Shanusascarabus » 21 Oct 2017, 22:30
So 35/36 psi all round sounds about right in all 4 corners then
Re: Shanes E92 335i
Post by Metroreg » 21 Oct 2017, 22:42
Shanusascarabus wrote:So 35/36 psi all round sounds about right in all 4 corners then
That’s what I will go for
Got the same on mine next year got some csl to fit on my e46 vert 225 on front 235 on back
Shanusascarabus
Re: Shanes E92 335i
Post by Shanusascarabus » 21 Oct 2017, 22:52
Thanks mate.. a great help
Re: Shanes E92 335i
Post by M60NJP » 22 Oct 2017, 08:35
+1 for 36 psi all round unloaded.
Shanusascarabus
Re: Shanes E92 335i
Post by Shanusascarabus » 12 Mar 2018, 18:01
it's been a while so what have i been up to....
Well the 335i has had a new radiator fitted and a genuine BMW OFHG along with new coolant ....... now all leaks have gone finally... car is still running sweet... apart from in snow.... worst car ever !!!
Next up a walnut blast and I must find some new mats from somewhere
