Bluetooth Coding
unofon
Car model: BMW 2007 E90
Bluetooth Coding
Post by unofon » 29 Apr 2015, 15:17
I have just bought a BMW 2007 320 E90 man date 07/2007 with I drive
There is a Bluetooth unit in the boot High Bass speech not High basis voice command works with the navigation etc but no phone showing up on the I Drive
I took it to a local BMW but the said the could not find the module on their software
I have now purchased a newer high basis unit and awaiting software and the plug to code the unit
What is the procedure and code required to get this to work?
it has
6Fl and 620 listed in the vin info
Any help greatly appreciated
Re: Bluetooth Coding
Post by M60NJP » 29 Apr 2015, 17:41
I'm sorry, but I can't understand this post at all!!
unofon
Post by unofon » 29 Apr 2015, 19:24
Sorry but im confused with all of this myself
Basically what are the codes to get the MULF 2 to work
Post by M60NJP » 29 Apr 2015, 19:33
I've no idea if the codes are publically available, but if you can find the code you'd need full INPA software to install it - plus the module is specific to the car so if it's a used one you've got, it will need your VIN inputting. One for a BMW independent garage I reckon!
unofon
Post by unofon » 29 Apr 2015, 19:51
Thanks will start looking
Return to “How to guides”
