BMW M51 325TDS / M41 318TDS Diesel Cruise Control
Post by Metroreg » 27 Aug 2016, 19:50
Just completed a Retrofit Diesel Cruise Control in my 325tds
Here is what you need
Cruise control switch - 61318360927
http://www.realoem.com/bmw/enUS/partxre ... series=E36" onclick="window.open(this.href);return false;
Create Wiring loom from the X69 connector by the fusebox two cables needed Green and Brown / Green (Green goes to pin 2 and Brown / Green goes to Pin 3 Replace existing pin3 cable)
The other side of the cable Green cable goes straight to Cruise Control Switch, Brown / Green needs to be split one of the cables goes to the Cruise Control Switch, the other length of the Brown / Green cable replaced pin 8 in the throttle plug.
Attached is the BMW Install guide for the Cruise Control
43.PDF
(285.57 KiB) Downloaded 617 times
Re: BMW M51 325TDS / M41 318TDS Diesel Cruise Control
Post by cockneyrebel » 27 Aug 2016, 19:55
Good item Sam..
Sent from my RM-875_eu_euro1_212 using Tapatalk
Post by Maxwell » 27 Aug 2016, 21:45
well done Sam knew you would figure it out in the end :thumbup:
Post by lizzie » 28 Aug 2016, 06:53
Nice work Sam
Post by Discostew38 » 28 Aug 2016, 16:25
Good job :thumbup:
Hopefully you've done it right
If I hear on the radio the police are chasing a 3 series BMW on the M25 and the owner is flat out in the outside lane and not stopping for them
Il be thinking of you :d
Post by Metroreg » 28 Aug 2016, 16:31
Thanks all lucky all tested and working it deactivates when the brake pedal is pressed or the switch is turned to the off position
Return to “How to guides”
