730D Electonic handbrake
chrikeia
Car model: BMW 730D SE
Post by chrikeia » 02 Dec 2017, 20:20
Hi Guys,
Is there a different way the electronic Park brake is supposed to be tested on the 7 series for the MOT.
It failed for a few strands of wire cut in the cables so I fitted 2 new cables and cleaned up the shoes.
It has failed again on low efficiency.
Now with my wifes car, which had just passed you drive along, put the handbrake on and its slows down to a stop over a distance,
you put the handbrake on and you can drive off easily something I am sure we have all done.
On the BMW you press the park button and it feels like you have stamped on the brakes, it almost tries to put you through the windscreen, try to drive off from a stop and it takes considerable effort.
It seems like it also applies the front brakes as the brake pedal locks down when the button is pressed.
Only thing I can think of with the handbrake seeming to be so good is should the test centre be testing 4 wheels or even if this is possible?
Thanks for any advice, Keith
Re: 730D Electonic handbrake
Post by cockneyrebel » 02 Dec 2017, 20:27
Hi, can i have year etc & I'll ask my mate. (MOT er)
Post by M60NJP » 03 Dec 2017, 09:26
I'm fairly certain the EHB only works on the rear. I assume your Wife's isn't a BMW?
Post by RayB » 03 Dec 2017, 09:38
Why would you be putting the hand brake on whilst driving or leaving it on whilst pulling away?.....
chrikeia
Post by chrikeia » 05 Dec 2017, 11:08
Its a 2007 730D, and I put it on just to try it, no I usually drive round with the parking brake onI was just trying to see how good it was
Return to “How to guides”
